New , lookin for tips and advice
jpsilvia
Car: 96 s14 with red top sr20
i recently bought a 96 s14 and swaped in a redtop sr any advice would be apreceated
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
lol, wut?
Morph
Car: 91 Sr Powered Coupe
Make sure it has gas, usually helps to drive. Oh and check tire pressure.
Mercury_Hg
Car: 1993 240SX Coupe
Make sure you replace your exhaust bearing. I don't know where you bought your SR from, but those go bad on S14s all the time. And then it's boom! Whole engine is trash.
Morph
In all seriousness if you have a more specific question might want to post it up.
badbob2121
costa_rican13
Car: 1993 s13 coupe
make sure you check the blinker fluid. those resevoirs like to crack on s14s all the time. its rediculous.
and make sure the battery is full of water too.
Mercury_Hg
costa_rican13 wrote:make sure you check the blinker fluid. those resevoirs like to crack on s14s all the time. its rediculous.
Make sure you get distilled water. Regular tap water will ruin your batteries.
costa_rican13
Car: 1993 s13 coupe
actually only smart water will work. so visit your local grocery and pick up some smart water.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Advice? make sure you car has good clean oil at all times, don't over rev your motor or you run the risk of your motor doing bad things to itself, Nissans seems to like to overheat when unhappy so make sure cooling system is on point.... other than that, make sure you have an LSD and then drive.
jpsilvia
well, i guess i had that coming lol , ive look at diffrent lsd's wats the most street friendly 1.5 way ?
costa_rican13
Car: 1993 s13 coupe
tomei
badbob2121
that depends on many factors, mainly on your description of "street friendly"
yours might be different than his ^^
what are you doing/ plans with the car?
you need to be more descriptive... alot more...
simmode1
Car: Red '95 S14
^^^ :werd: But generally, J30 and S15 diffs are the most street friendly LSD upgrades.
costa_rican13
Car: 1993 s13 coupe
simmode1 wrote:^^^ :werd: But generally, J30 and S15 diffs are the most street friendly LSD upgrades.
:werd:
