New look engine bay.......
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
Got my old mani & o2 housing going out for swain coating and a freddy intake getting powder coated gloss black? Should I do matching candy red on the mani or balck? I'll have a dyno sheet on November 1st with new intake, tomie procams, and 24psi.
snake240
Car: 92 hatch SR20DET
nice
go with black on that mani
Sabot
snake240 wrote:nice
black
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Very clean! Question, what size hose fittings and hose do you have on that T-fitting on the valve cover?
Kalypso
snake240 wrote:nice
No!
overall it looks a lot nicer,
kentuckyslider
positron_ wrote:Very clean! Question, what size hose fittings and hose do you have on that T-fitting on the valve cover?
-12 an earls line from summit and -12an fittings. they fit perfect on 15mm fittings. I was supposed to get a CS small catch can from mysr20.com but they forgot it and a 2.5-3" coupler for my intake pipe. The CS catch cans have 15mm fittings also. That and a BMC heat shield is on it's way.
Kalypso
strut bar?
you should get some altima fans,I got mine from a junk yard for 17$
... but its not necessary.
kentuckyslider
Kalypso123, No on the powder coated intake, or no on black for the color?
sr20deTsomeday118
Car: 1991 240sx/se coupe
no on the black color. black is a heat soak. things are hot enough in there
RPS13 DRIFTER
Car: S13 Hatch SR'D
kentuckyslider i want your setup for drifting,i know you have the gt2871rs with the .64 exhaust what injectors and rom tune do you have?,also how is turbo response?
ryan15
Car: 1990 240sx
What kind of maf is that q45?
kentuckyslider
All JWT setup......... 72lbs injectors, ford cobra maf, and JWT rom tune. It maxes out at 475 whp with the cobra maf and 72lbs injectors. The injectors are = to tomie 740cc. Also walbro fuel pump, fpr, and jgy top feed fuel rail. I have a fully built bottom end with 86.5 arias pistons, eagle H-beam rods, acl bearings, arp head and main studs and rod bolts. Installing cams and doing a dyno run at 24psi next week. Hoping for 380+whp with stock intake and 340+ tq. That's with a 4.36 R&P.
RPS13 DRIFTER
Car: S13 Hatch SR'D
will 550cc innjectors support 350 wheel with a 2871rs?
Emperor_Tha
is that s13 hot pipe with a t25/t28 adaptor? Request more pictures
kentuckyslider
Emperor_Tha wrote:is that s13 hot pipe with a t25/t28 adaptor? Request more pictures
No, it's a standard Gt2871R with a 3" inlet and 2" outlet not the SR bolt on. It has a 90 deg elbow from jgy with 2" hoses. Greddy rspl FMIC.
