New little dash mod.
nimbyfaygo
Car: 2004 G35x
I made my own little grille for my double din whole with a single din headunit.
All I did was take an old grille cut it down to fit and re glue it. I took a Q45 symbol and epoxied it. I think it looks pretty cool.
pdqwrx
Car: 1989 240 SX, 2002 WRX Wagon, 2003 FORD f150 4DR
Looks good, just an idea though. If you painted it or covered it black it would look like the rest of the black backrounds of the heater control and shifter, it would look more OEM. Passengers who didn't know better would think that Infiniti put that together. Also, if it is a mesh speaker grill you used, you could back light it with a small neon tube (Available at Pep Boys etc.) so that it would "Glow" when your in the mood.
CheersScott
pdqwrx
Another little Nissan/Infiniti detail you can do is to re drill the radio brackets so the radio will slide about 1/2 an inch back and rest where the stock radio did. That way it will look like the rest of the black areas of the dash where the material rolls into the control.
CheersScott
nimbyfaygo
Car: 2004 G35x
pdqwrx wrote:Another little Nissan/Infiniti detail you can do is to re drill the radio brackets so the radio will slide about 1/2 an inch back and rest where the stock radio did. That way it will look like the rest of the black areas of the dash where the material rolls into the control.
CheersScott
Now thats a good idea. I'm going to try that tomorrow if I get the time.
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
That **** is hot. What do you mean by grille? How hard was it to do something like this?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
wow, that is unique, i like it!
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
What would realy be cool if there was a way to make that a door and have some kind of bin in there. There's a lot of room for a deep bin. Yea, I'd paint it black so it wont stand out so much.
pdqwrx
Over the years, Nissan has made many bins with hinged doors on them. The cool thing about older Nissan radios is that they are all pretty much the same bolt pattern and width and height. So if you were to spend some time at a autowrecker or a pick N pull you should be able to find the bin you are looking for. I found one from a old stanza that I am using in my 240sx. I cut out the back and installed my turbo timer behind the door so I can hide it from view. Anyway, if the pocket looks faded or dirty just run it through the dish washer and then paint it with a satin black or matte black paint and it will be as good as new.
CheersScott
nimbyfaygo
Car: 2004 G35x
I added two 8mm white LED bulbs today. Looks amazing, I've never seen anything like it. I mounted the bulbs on the bottom pointing up so the light reflects off the underside of the headunit.
Of course this creates more problems. First the letters are partially blocked by the mounting ring There are random tabs sticking out on the mounting ring I made that didn't show until they were backlit. Plus you can see the brackets and wiring back there. I can make the opening translucent instead of transparent by putting a piece of wax paper behind the grille cloth. And I can use my dremel to smooth the edges of the ring. That still leaves the issue of the letters being blocked and off center
Haitian_King
where did you get a grille from?
nimbyfaygo
Car: 2004 G35x
Haitian_King wrote:where did you get a grille from?
I made it from a little home theater grille.
Haitian_King
is this grille metal? Or fabric? I'm interested in doing something like this my Q.
CINNALOCKS
Car: 1994 Q45A Converted/ Burgundy & Tan /TokicoBlues /JWFSTB/ Silverstars/ Upgraded ECU
Nice Idea indeed.What happened to painting it black? It will look more like oem and at least one issue disappears. No longer will see the wires and connectors.
Just a thought, but how about just illuminating the "Q45 emblem" instead of the whole piece?
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
The Q45 badge looks as though it was mounted too high anyway.
Is it easy to remove the badge and relocate it?
Maybe you will have to make another one if you can't.Just put it down to a "live and learn" experience.
I do like the way it's all lit up though.
Instead of wax paper, how about using a piece of aluminium foil, and attach it behind the LEDs, so the light reflects off of it. Maybe try a flat, smooth piece vs a crumpled, rough piece and pick your favorite.
Hell, just decribing it makes me want to see what it would look like now........
DOOO EEEEEET!!!!
PS: find a way to replace the analog clock globe with a white LED too, to help tie it all together. See, you change 1 thing, and now it snowballs
Ozzie
'06 MK5 Golf tdi
nimbyfaygo wrote:
I also noticed, yet another shifter that is opposite to mine.
You move the shifter down, and to the left to go into "D", then down, right, down, right into 3rd, 2nd, then 1stMine goes down and to the RIGHT into "D", then down , LEFT, down, LEFT into 3rd, 2nd, then 1st
I think CrimnsonQ said his also goes to the right into "D"
Anyone know why there would be a difference?
pdqwrx
You could also paint the grill black and then mount the Q45 emblem behind the grill and back light it. That way you would only see the Q45 when it was lit up..... Very stealth and cool
nimbyfaygo
Car: 2004 G35x
ozzie! wrote:The Q45 badge looks as though it was mounted too high anyway.
DOOO EEEEEET!!!!
I will have to replace the cloth. I can't get the emblem off without ripping it. I know that its too high, I just have to wait untill I get some more cloth.
I'm working on the clock right now LOL.If that comes out nice, I'm going to try the gauge cluster.
BTW I got the LED's from Ebay, the seller is *spectrumleds* Here is a link to a similar item. http://cgi.ebay.com/20-5mm-60-...wItem
nimbyfaygo
Car: 2004 G35x
Haitian_King wrote:is this grille metal? Or fabric? I'm interested in doing something like this my Q.
Its fabric. I wrapped the cloth around a little plastic ring I made.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
ozzie! wrote:I also noticed, yet another shifter that is opposite to mine.
LHD vs. RHD.
Q451990
I bet you also have the shifter position indicator in your instrument cluster? I tried to buy a JDM cluster on eBay once, but got waaaaay outbid.
Heath
Ozzie
'06 MK5 Golf tdi
Indeed I do...... An unnecessary addition in my opinion.
Modified by ozzie! at 3:13 PM 2/22/2007
Haitian_King
Wish I had one. My instrument cluster looks so plain. It was weird going from a Jeep Grand Cherokee to my Q. Like I had an oil pressure gauge and everything.
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
I like that idea!
pdqwrx wrote:You could also paint the grill black and then mount the Q45 emblem behind the grill and back light it. That way you would only see the Q45 when it was lit up..... Very stealth and cool
