Tech, I am posting this as sort of a thinking out loud sort of thing, please critique as you see fit. I'm not trying to preach or say I'm right, I want to find out if I'm right
Ok.. so lets assume 4136 (94 Q45t), 3850 (CURB WEIGHT, NOT AS TESTED), 4020 (for another 90 Q, 1989 C/D), and 4160 for anothet 1990 Q ..... weight distribution is roughly 58/42 (some have said 57/43). 95 Q had a 4240 test weight.
IMPORTANT to realize that NO Q45 actual test weight was below 4000 LB... Curb weight certainly was, but of course the tested weight may or may not have had drivers in it. So from those numbers lets say (throwing out the lowest one), lets work with the heaviest one listed, 4240lbs.... I think its probbaly fairer to use these heavier weights which likely include driver...
So extrapolating this data, youd be left with 1230lb up front per (2459/2)... So according to my calculations thatd mean we'd want at least 1328lb load rating up front (1230 x 1.08=1328).. Which means of course the closest load rating to that is 91 (1356). With 91 load tire youd be over the minimum by 2%... Still within the safe margin according to what your saying...
http://www.tirecradle.com/tire...tings:
For a michelin tire or equal quality (if such a beast exists) I would think that a 91 load rating would technically be safe, however you might want to go for a 93 load rating to be 8% over the min.
however stock pressure of 28PSI is only 64% of the 44psi (i assume stock tires were a 44 psi). Since they inflated them less, that would the load rating seem less... Even though it was a 95 load tire, it didnt seem like it because they were inflated at 80% of the load tested [35PSI]. SO if they inflated the tires to 35 PSI, a 93 load rating may have been sufficient from the factory.... ALSO clearly you could get away with a lower load rating on the rear of the car if you wanted to, but if you run the same size tire or a wider tire in the rear this isnt a big deal.
One thing its important to realize that I am not advocating using less than 95 load rating, but if what your saying is true, a 93 load rating on a good tire should be fine.
