SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Mon Jan 12, 2009 1:19 pm
Hi there and welcome to Nico.
From your initial description, I think it is safe to assume that you are in need of a Drivers door lock actuator. I usually verify this by locking the door and hitting the unlock bottom on the remote or by using the key in the lock. Paying attention to the movement of the locking button, if it moves just a little (almost a flicker) then the actuator inside the locking mechanism is no longer working as well as it should be.
As for your remote program, I know the procedure is around here somewhere but I do not think that replacing the BCM is going to fix your issue.
