StryfeS13 »
https://forums.nicoclub.com/stryfes13-u150110.html
Wed Jun 15, 2011 3:58 pm
Am I the only one on this planet that can't have a running boosted car? Damn!
Here's the mod list:
Supertech 8.6:1 Forged pistons
Eagle forged rods
ACL bearings
ARP main studs
ARP head studs
Fel-pro high pressure headgasket
Ported/Polished/Port matched cylinder head
All new gaskets
New valve seals
Holset H1C turbo
EFI Specialist Tune
Tomei 555CC injectors
Z32 MAF
Walbro 255 LPH fuel pump
Here's the problem:
My car has a consistent miss at idle. When I first started the car it flooded out cylinder 1 and had so much fuel it was leaking out of the exhaust port. I pulled the injector out and reseated it, and the cylinder slowly started picking back up.
I also changed the spark plug and wire for cylinder 1. My car still has a miss. I'm not sure if it's that cylinder anymore, but it's still missing at idle and I'm wondering what could cause this?
Also if I try to rev it up fast at idle it will stumble and sometimes die. But if I slowly rev it up, it will be fine.
There is also a small exhaust leak at my v-band before the o2 sensor.
Here's what I've done:
I pulled out the rail and turned the key to the ON position. (could hear my walbro priming)
No leaks whatsoever from the injectors.
I also checked my oil and it has no smell of gas at all, and is not overfilled or anything. (i'd imagine if gas was in there the dipstick would read higher)
...I have tried two different turbo set ups now, and both times they do this crap. What is up with my motor?
-And before it is said, the timing is notttt off.
