New K&N Intake buzzes when throttle is fully pressed down
All things Altima Coupe.
Gdudeac2511
Car: 2011 Nissan Altima Coupe 2.5S - Metallic Slate/Charcoal Leather
I just installed a K & N Typhoon Cold Air Intake into my 2011 2.5 Altima Coupe. Whenever I floor my car it makes a buzzing noise and I cannot figure out what it is. I have double checked to make sure all screws etc. is tight. Has anyone else had this issue or know how to fix it? Thanks in advance.
spiderwebfx
Car: 1985 Nissan Silvia S12
It's not just a intake noise now that you no longer have any intake mufflers or anything? (Presuming it had them originally of course)
Gdudeac2511
I have no other mods to my car so it shouldn't just be the intake noise. It starts at about 20mph and has an annoying buzz noise until I let off the throttle.
spiderwebfx
Is it more noticeable under WOT or just after 20mph?
Gdudeac2511
after 20...before 20 I just hear the intake which sounds good but then after 20 the buzz noise takes over.
Gdudeac2511
And I don't hear it at all if I am not on WOT
spiderwebfx
I am guessing it's due to the factory intake piping being removed and having the K&N setup installed. The factory one is all plastic with an intake box and resonators which all helps reduce intake noise. The new kit is a alloy tube and a pod-filter (I think?). The alloy tube will also generate more resonance than what the plastic noise is.
Look at this http://www.youtube.com/watch?v=9ocAlvufiR4
Is it similar to the noise when he blips it after the kit's installed?
Gdudeac2511
No, it makes that noise that sounds good! However the buzzing noise kicks in too...anyway. One more question, when I rev it it seems to stop at 1000 rpm for a couple seconds, than drop back down to normal. Do you know anything about that?
spiderwebfx
That is standard across most car's when they're cold I thought.
As for the buzzing, I'm not too sure.
Ranga14
Car: Boosted 08 Altima Coupe 3.5
Check to see if a bee got trapped inside the intake. :yesnod
xshinnyshinx
My car was doing that too like right after I installed an intake. I checked it out on a day I wasn't busy and I think what I did was move the big filter thing away from the part closest to the car and tightened the bolts more. The intake shakes when I gun it and hits the wall, that's what was happening to me.
Gdudeac2511
Yeah, I think whats happening is it is hitting the heat shield when I get on the pedal, which in turn vibrates the heat shield which is connected to the bracket to my car.
