evildky wrote:and with intake and exhaust covered if you intend to stay N/A an ecu would go well with the intake and exhaust
Couple Questions:
1. Does the stock ECU "learn" new tricks? I've only seen this mentioned one place. My Cougar learns it's settings everytime that you reset it. (You have to reset it, it doesn't reset everytime you start the car or anything.) Does disconnecting the battery cause a reset on the 300ZX?
2. With an ECU upgrade, I have seen two main names; JWT and Ash-Spec. Is one any better than the other?
3. Is reliability an issue with an ECU upgrade? I mena, while 82 - 84 K miles isn't a lot, do I need to be concerned by anything when using an ECU upgradde?
4. Finally, UltimateZ shows a "computer upgrade" as "Stage II" for an N/A car, but wouldn't it be better for me to get the new exhaust on first? I assume that I will need to tell the ECU manufacturer what my current upgrades are. (Is that true, or does it matter?)
Thanks,
Ken
