105K for the first time according to the owner's manualjoefast wrote:1- timing belt
depend on what kinds of plugs you usejoefast wrote: 2- spark plugs.
Just like any other cars fluids, filters and plugs.joefast wrote:what is involved in routine tune-ups for this car.
Actually if the belt is original then the first time should be 60kNismoChi wrote:105K for the first time according to the owner's manual
May be for 93, on my 94 owner's manual, i state that the first one would last 105K miles.DominickJ30 wrote:Actually if the belt is original then the first time should be 60k
Yes you are correct that is the interval for a 93 with original belt. Try to get the kevlar one if you change it.NismoChi wrote:May be for 93, on my 94 owner's manual, i state that the first one would last 105K miles.
Contact the dealership that did the service and they will tell you.joefast wrote:I was looking around the engine today and found a dealer sticker that the timing belt had been replaced at 55K in 1999 by INfinity. Would they have installed the kevlar or regular belt in 1999? Is there any way to know?
Also any ideas on the rear suspension noise?
Thanx for the help
JOE
VimyJJ wrote:All replacement belts were/are the improved Kevlar type. However, 100k is the time to replace hoses, belts, water pump, tensioner pulley and thermostat. Perhaps some of these preventitve maintenance measures were performed when the original timing belt was replaced. Check your records.
That's utter crap.yodawill2000 wrote:I called them and they said I had to bring the J in to verify the Vin.Hope I dont get a "Its gonna cost ya" line .
