stop it, marty1mc, just stop with all the sensible and coherent advice.marty1mc wrote:If you are rebuilding, there are a couple of options. You could simply purchase a short or long block from either Z1 or ImportPartsPro.com. You can also buy a rebuild kit. Z1 sells two, but I would recommend this one:
http://www.z1motorsports.com/product_in ... ts_id=2833
For the levels of boost you are talking, stock internals are fine. I currently run sport 500's and boost around 18psi on high boost. The thing you need to look at is upgrading your injectors, ECU and intercoolers if you want to exceed 14-15psi.
vulcanrush wrote:stop it, marty1mc, just stop with all the sensible and coherent advice.marty1mc wrote:If you are rebuilding, there are a couple of options. You could simply purchase a short or long block from either Z1 or ImportPartsPro.com. You can also buy a rebuild kit. Z1 sells two, but I would recommend this one:
LOL. Yea, I don't even realize I am doing it until it's too late. Maybe I should go see someone about this problem.vulcanrush wrote: stop it, marty1mc, just stop with all the sensible and coherent advice.
yes, on the exhaust manifolds, get msp's. are your 555cc's injectors the new-style ones? if not, i'd opt for nismo740cc's, new-style ones.EM.TT wrote:Lol @ vulcanrush. But yea I looked into those kits and thats probably what I'll do. I already have 555's but need the rest. Another question, is it worth it to get new manifolds?
Will it run weird without the new style ones? also couldn't I just get the 91 octane fuel without ethanol (and tune?) or novulcanrush wrote:they're fine for what you want, it's just they don't handle ethanol gas as well as the newer-style ones.
stock internals are good for that.EM.TT wrote:Will it run weird without the new style ones? also couldn't I just get the 91 octane fuel without ethanol (and tune?) or novulcanrush wrote:they're fine for what you want, it's just they don't handle ethanol gas as well as the newer-style ones.
And I'll look into the forged stuff as well. Although my last NA made a ton of noise internally and it really pissed me off. I don't plan on getting over 420-450 rwhp and from what I understand stock internals are good?
FYI stock TT internals are forgedkawininja91 wrote:If your rebuilding your engine you might as well go with forged internals. Better do it now than later when you want to increase power and have to tear the whole engine down again.
itsa300zx wrote:FYI stock TT internals are forgedkawininja91 wrote:If your rebuilding your engine you might as well go with forged internals. Better do it now than later when you want to increase power and have to tear the whole engine down again.
On cold start lower end forged pistons tend to slap prior to warming up. This is normal and expected.es.biggs wrote:Piston slap is caused by worn pistons and cylinder walls, or when there is excessive clearance between the two. Forged pistons won't make any more noise than cast if everything is done properly
Rebuilt as in take it to a shop and have it bored and so on? or a new shortblock?BigTDogg (MA) wrote: Close, but no cigar.They're cast pistons and forged connecting rods.
To the OP, OEM internals will be fine for your power levels and current goals, as are your 555s. You can run 91 octane and up on them without issue. The biggest issue is the ethanol in many fuels. If you currently have a source for ethanol free fuel, use it, as I'm pretty sure the hippydouchebags in government will be pumping it up to 15% shortly.
Also look into the switched +12V injector power mod. This will also save your injectors some life.
If the compression issue is in the heads, you can re use your OEM bottom end, provided it's in good shape. If the rings are the issue, you'll need a rebuilt bottom end. In that case, as previously mentioned, Import Parts Pro is one of (if not the) best large volume VG builder in the country.
Rebuilt as in replace the pistons, rings and hone the cylinders yes.EM.TT wrote:Rebuilt as in take it to a shop and have it bored and so on? or a new shortblock?
And at that point would it just be cheaper to buy a new shortblock? I have no idea what a shop would charge to do that kind of work.
I think it could definitely be a head gasket. All the driver side numbers are way low. Compression check should be done with the engine warm for maximum numbers, but I doubt there's any value in doing it again on this one.EM.TT wrote:Ok, and as for the compression I think I'm going to put the starter back on and test it again just to be sure, and add oil this time as well.
These were my numbers from the first two compression tests (the car overheated, has been sitting for roughly 5 months, and hasn't ran since it overheated)
1 - 110
3 - 90
5 - 90
2 - 30
4 - 15
6 - 50
That wouldn't be a head gasket would it? Those results were without adding oil and the plenum off.
and wisecos too, Tony, appreciate the explanations so i didn't have to do the typing.BigTDogg (MA) wrote:On cold start lower end forged pistons tend to slap prior to warming up. This is normal and expected.es.biggs wrote:Piston slap is caused by worn pistons and cylinder walls, or when there is excessive clearance between the two. Forged pistons won't make any more noise than cast if everything is done properly
From what I've read/seen, arias and other higher silicon content pistons won't slap as much. This is just what I've read from other first hand accounts, not my own experiences.
The reason forged pistons slap before they warm up is that they expand slightly once they're warm. Higher silicone content minimizes this growth, so the pistons don't slap the cylinder walls as much when they're cold.BigTDogg (MA) wrote: On cold start lower end forged pistons tend to slap prior to warming up. This is normal and expected.
Lol, yea that was basically my only option after seeing those numbers! But I'm looking forward to it. Its basically ready to come out already and I want to delete all the useless systems and repaint the engine bay as well. This car I bought has THE DIRTIEST engine bay i have ever seen on a Z... it's ridiculous.es.biggs wrote:Woohoo time to pull that baby out and fixxer upppp
Sorry vulcanrush...didn't realize that about the piston slap...I've never heard it before, but I've never listened closely either.
Right, forged materials in the same (relative) volume are more dense than a cast part, longer to warm up. The silicon content also makes sense, I just didn't want someone bitching to me if they bought them and they still slappedcar nut wrote:The reason forged pistons slap before they warm up is that they expand slightly once they're warm. Higher silicone content minimizes this growth, so the pistons don't slap the cylinder walls as much when they're cold.BigTDogg (MA) wrote: On cold start lower end forged pistons tend to slap prior to warming up. This is normal and expected.
