NEW interior mod
All things Altima Coupe.
Mr_Coupe
Car: 08 Code Red 6 speed manual transmission 3.5 v6 Altima Coupe
It was pretty simple i got sum vinyl red interior paint from ebay i tapped off the parts i didnt want painted. and i also used news paper to block of the bigger areas. then used a few coats and it came out pretty good. i got a little bit of paint on the interior but took it out with paint thinner (that thing works wonders) here's the results
Before:
after:
and the shifter:
mcheddadi
Car: R8
Nice!
CoupeSlate
Car: 08 Altima Coupe 3.5SE CVT, Dark Slate Premium Package
looks very nice
where is Ms. Coupe
Mr. Music
Car: 2008 Altima Coupe 2.5S CVT w/ Convenience Package
In the family: '02 S15 Spec R, '09 Rogue
Nice! I wanted to do that, but I'm thinking about getting some carbon fiber and wrapping it. My question though: why did you choose to paint those trim pieces in the car? A small screwdriver to the bottom and they peel right out, there are four clips if I remember correctly...
Silver Dollar
Car: 2008 A/C Coupe 2.5S Premium /w CVT
Nice If you are looking for another spot to paint - that plastic retainer at the base of the stick (the one that clamps the leather skirt down) might be another option..
edit: just noticed the red air freshener peeking out too
D-Roll
Car: 08 Nissan 350Z Touring Coupe
Good job!
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
Mr. Music wrote:Nice! I wanted to do that, but I'm thinking about getting some carbon fiber and wrapping it. My question though: why did you choose to paint those trim pieces in the car? A small screwdriver to the bottom and they peel right out, there are four clips if I remember correctly...
Yeah, I was thinking the same thing... waaayy too risky, next time, just pop them off!
Absolute Zero
Car: '08 Nissan Altima Coupe
+1
Mr.Coupe
Car: 08 Altima Coupe 3.5 BOOSTED
CoupeSlate wrote:looks very nice
where is Ms. Coupe
Here I am. It's not my style, but it's a good clean looking job dude.
Ricky C.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Nice Job man! I was thinking of doing the same thing but wanted to take off the pieces rather than painting them in their FRP (final resting place).
Doc, you said, just pop them off. how? Is this in the FSM?
Mr. Music
dangeris wrote:...just pop them off. how?
To pop off the silver pieces on the door, I used a small flat head screw driver to pry the bottom away from the door panel. Once you can get your fingers behind it, carefully pull it away; there are four or five clips that hold it in place. Once you are done with it, just snap it back in place. I'll see if I can do a mini write up on it, lol...EDIT: OK, here we go...
First: Take your small screw driver to the bottom of the piece.
Then pry it away from the door panel. This will separate a small clip right were I have the screw driver.
Now grab the end of the piece with your finger tips and pull it away some more. Then continue moving up the piece, pulling out the clips. It will take some force to pull them out.
It's off!
To put it back on, snap in the topmost clip, then work your way down.
Done! Hope that helps.
Modified by Mr. Music at 10:12 AM 5/3/2008
Sith LL_Coupe
Car: Precision Grey Altima Coupe 3.5 SE CVT (Prem. & Tech. Pkg.)
Looks sweet!
(No hijack intended), but I was just at the dealership and their showcase model for the Coupe had the whole inside carbon fibered out, side panels which you painted, the accent on the gearshift and the center console, it looked pretty sick...
I'm guessing we'll be seeing a lot more interior mods now that the car has been out for awhile and most people have done their exterior work already to the way they want it. I don't think there is much honestly to do on the inside, the A/C is pretty luxurious on the inside imo.
Jlor1002
Car: '11 Altima Coupe 3.5SR
Does the silver plastic piece at the base of the stick simply pop off as well? Mine is scratched, looks like hell, and drives me nuts. I want to wrap it in carbon fiber vinyl, but don't want to start just try prying s*** off... tried searching for an answer and this 4 year old thread was as close as I could get.
Also, it's hard to get a feel for the CF colors on a computer screen - any suggestions? I don't have anything else wrapped and don't want it to standout / look awkward (silver '11 w/ red leather interior), I'm just tired of it being scratched up and this seemed like an easy/cheap fix ($6/sq ft on amazon). I'm thinking black, graphite, or silver... but hard to tell w/o having seen the CF in person.
mmx23z
Car: 2008 A/C 2.5s CVT
:bigthumb: for using the search button!!
u mean removing the plate under the shift knob?
yea, remove the shift knob & just grab onto the plate & pull it off (only clips) same for mt & cvt
heres a pic of mine... like u said hard to get a feel but its best i could do
Jlor1002
Thank you! I'd be lost w/o this forum. Haven't posted much (nooooob) but been readin A LOT...
Jlor1002
My CF wrap came in and I got this done this morning. Super easy to do. The piece I wrapped is screwed onto the plastic below, which is only held in w pressure clips. I ordered some more (graphite) so i can do the doors as well.
The razo knob set up looks huge in that pic. Not as bad in person. Funny angle.
