Red-KAT »
https://forums.nicoclub.com/red-kat-u14022.html
Tue Mar 15, 2005 5:10 am
Right off the web site.
LC-1 in Final Pre-release
The LC-1 (aka Lambda Cable) is a complete wideband controller built in to a sealed and rugged cable. It features the same industry-leading patented digital circuit found in the proven LM-1, and includes digital in & out, plus two programmable analog outputs. The LC-1 can connect directly to the XD-1 for a standalone AFR gauge, and is ideal for using with an ECU, a piggy-back fuel controller, a laptop/OBD-II tuner, a separate data logger system, or a dyno. (If your dyno has analog inputs, you can start doing 8-cylinder tuning without even waiting for LogWorks 2.0). MSRP on the LC-1 is $199 with a sensor, and $149 without a sensor, so you can see we’re still serious about bringing you the best in pro-quality digital tools at prices for the pro and enthusiast alike!
BTW this is a XD-1
The bezels are cut. The firmware is done. The cables are molded. The light-emitting (and light-sensing) diodes are in. The test fixtures are testing. The wait is over. The XD-1 is shipping! With a ton of innovation, we think the XD-1 was worth the wait:
21 programmable RGB "needle" LEDs Remote control button to start/stop log sessions, calibrate sensors, and view min/max holds Total thickness of ¾” allows surface mount or thin-pod installations Programmable warning lights with multiple dependencies Universal design can display AFR or any channel that LM-1 is logging User-replaceable dials with web tool for printing custom dials / gauge faces
I know people like options so here are more... I'm sure some of the sponsers will be selling these
