If you are running mild bolt ons, such as intake, dp, fmic, exhaust, o2 extension, and light boost on stock turbo, stock injectors are enough and should be good.
if you get newer turbo and is making 270whp, then chance is that your car is pretty modified. Your car will burn more fuel. Though, if you just upgrade the fuel injectors, your fuel pump MAY become the bottleneck, so its good to do both. If you are making even higher hp later on, you must get fuel managmenet for safety.
Damn, I could never imagine myself running 270hp at the wheels. Too many things to worry about; head gasket, pump, injectors, turbo, confusing electronics.....sigh......
boltons and light boost is good enough for me
