95lstegman »
https://forums.nicoclub.com/95lstegman-u33967.html
Fri Nov 11, 2005 10:17 am
if you just want a little more power you can push the fuel pressure up a bit. the stock SR20DET fuel pressure regulator is a rising rate unit providing 1psi increase in fuel pressure for every 1psi of boost. a lot of the FWD guys raise base fuel pressure from ~45psi stock to 60psi with the Nismo FPR. "the 4 bar fuel mod" or something is what they call it. i'm not sure how much more power that will support, but it will need dyno tuning in any case. i don't think that kind of fuel pressure would be bad for them, as i've seen Honda fuel injectors supporting over 120psi every day for a couple years on those "bolt-on" turbo kits they have for Hondas. they take stock 240cc/min injectors and slam the fuel pressure up 10psi for every psi of boost and many see 135psi fuel pressure. admittedly, these die after a couple years, but 135psi is pretty impressive that they will function at all, let alone actually run pretty well.
i guess my point is that if Hondas' Denso injectors can push over 125psi for a couple years, how come Nissan injectors couldn't hold 75psi (60psi base + 15psi of boost) forever?
