2_Liter_Turbo »
https://forums.nicoclub.com/2-liter-turbo-u12924.html
Sun Apr 10, 2005 11:17 am
The new injector came with all new O-Rings. And I also got a "seal-kit" just in case. Now I did hook up a pressure gauge to the feed line between the rail and the filter, and with the ignition on (fuel pump activated) it goes up to about 45 psi, but as soon as I pull the key out, presuure drops down to 0 and the #1 cylinder is full of fuel.
So now I am going to switch out the new for the old again with the rail off of the intake manifold and see if does the same. It is obviously leaking somewhere inbetween the injector bowl and the actual injector, into the intake port. So I'll post in a few, to my findings. By the end of this whole adventure I will probably be able to answer all kinds of "fuel injection" related questions
