ivatar »
https://forums.nicoclub.com/ivatar-u123289.html
Mon Dec 29, 2008 8:49 pm
1Hi everybody, this is my first post, i have a long time in this forum but only reading sorry for my english i m from Venezuela and i dont have practice at all, I have a nissan 200sx 1994 S13 ca18det (w/o secondary butterfly) I buy this car and in my first day spun bearing appears -.- (bad maintenance bad oils etc...) it remove the motor and making all new. I have a lot of question about it, the first one, i live in a tropical country (the minor temperature is about 23 C) i want to remove the water ducts and all warming system of the intake manifold somebody has done this already?
I want a daily car whit a least 350hp
My list of piece i will change and update in the car.
-New intercooler front mount
-Oil pump, water pump, walbro fuel pump
-Fuel regulator
-Piston wiseco
-Connectin rods pauter
-Cams gear tomei
-Head stud kit and studs intake ARP
-Head gasket cosmetic
-timing belt power enterprise
-Rob Bearing and Main bearing ACL
-Motor mount nismo
-Cluthc 6 puck ACT
I will make and oil cooler and place it in the older intercooler mount.
For now i will run with the stock turbo, injectors, ecu. Later i will update for a Gt3071R garrett and megasquirt tune for the suspencion i think i will buy megan coilover damper kits track series.
I appreciate any sugestion.
Some photos
Is sad and boring in my garage
Mitsubishi Crap
I will update soon
And the update and spun bearing and really bad maintenance for the old owner
The spun bearing a good rod bearing and the main bearing
Thats is not oil its wax
The crank in the spun bearing look good but waiting to january to do the test.
Modified by ivatar at 7:02 PM 12/31/2008
Modified by ivatar at 8:05 PM 12/31/2008
