New Idler Pulley still wobbles?
eduJ
Car: 1998 QX4
I made a thread a couple weeks ago regarding a noisy pulley. I replaced the pulley with a non-oem one from Napa Auto Parts. Although the squealing appears to have disappeared, the pulley still wobbles. I'm not sure why this would be the case. Would a belt that is too tight cause this?
atraudes
Car: 2001.5 Infiniti QX4 4WD
There's a nut on the face of the pulley. Is it torqued properly? It shouldn't be loose at all.
eduJ
Car: 1998 QX4
it's not loose. I torqued it to spec, but the pulley wobbles when it spins.
atraudes
Did you replace just the pulley or the bracket too?
If the nut is tight and the bracket is secured properly, I'd say you have a bad pulley/bearing. They most definitely should not be moving around like that.
eduJ
Car: 1998 QX4
Thanks for your response. I just replaced the pulley itself.
atraudes
I guess hit up Napa and see what they say then.
