:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Fri Oct 28, 2005 12:38 pm
~300rwhp at 12psi...runs low-13s at ~110mph.
Turbo (Garrett T3/T4, 57-trim), TiAL 35mm wastegate, DP flange, RevHard Manifold, SR 370cc Injectors, 1G DSM BOV, Autometer Phantom Gauges (AF+Boost), JGS oil lines and fittings, Mandrel Piping, Hose Couplers..._____________________________________________
All for $1,562, but add $100 for misc stuff like clamps, a brass "T" for the turbo inlet, RTV, vacuum hoses, etc...
So call it $1,662 ... non-intercooled setup, 224rwhp at 6psi.
Then I added the intercooler (new) and 2 more pounds-o-boost:
GReddy VSPL intercooler kit, $800 ... and you have ~$2,500 TOTAL for 250rwhp @ 8psi.
Then I upgraded the fuel to JWT, 50/lb.hr injectors, Cobra MAF, top feed rail...and upped the boost to 12psi.
*Used* JWT ECU and fuel setup, $600 ... and you now have $3,100 TOTAL for ~300rwhp @ 12psi.
I already had an ACT clutch, and have since added a full 3" exhaust ($200)...
...and I did EVERY bit of work myself.
I also waited for deals, searched the web, etc...and saved a lot like that.
My fuel system, for example...new, was $1200 or so...but I found a DEAL.
Hope that helps.
- Brian
