I guess it should. When I got mine, it wouldnt bolt on to my turbo elbow, dam SSAC welded the flange on crooked, (great quality I tell you what), lol, so I took it to someone and had them cut it and re weld it straight to match up to my exhaust. HKS FTW!driftin8nez wrote:Ya i'm scraping the cat when i do the swap. That SSA pipe is a dp and a "testpipe" in one. Does anyone know if it will bolt up to the stock exhaust system?
Thats sounds cool also. I'll look into that. So if i run a 3" dp to stock piping will it hurt gas mileage or just my hp? Becouse I plan to drive around mostly this way and when the ocational ricer comes up i'll just open her up and give it a rev. That will be enough to scare off most of the clowns in my area. Also that SSA dp/testpipe should be able to bolt up the my stock exhaust without any problems?capwred wrote:atpturbo sells one that works withthe vacuum.win boost comes on it opens,then when boost drops off it close.i have heard that it works great.
That thing looks neat but I doubt it will stay open when it has high velocity exhaust gasses hitting it.......I can just imagine the "trap door" would blow shut farily easily....its only an electric motor keeping it open and unless there is constant current going through the motor to keep it open (which would burn it up after awhile) it would easily push shut. Ever try turning an RC electric car motor with your hand?...it turns quite easily when there is no current going through it.driftin8nez wrote: Check it out:http://cgi.ebay.com/ebaymotors...64864So what do you guys think?
i bought that and IT DIDNT FIT so i had to cut the turbo side flange off and spin it then reweld it. i HATE SSAC but hey i have bad luck with everything so maybe yours will fit. but bolting that up to your stock should work, i mean everything iwas made to bolt up in those spots.driftin8nez wrote:That SSA pipe is a dp and a "testpipe" in one. Does anyone know if it will bolt up to the stock exhaust system?
I hope they got the flange right on mine. If they didn't i'm sure you guys are going to hear about it.yourmomsrps13 wrote:i bought that and IT DIDNT FIT so i had to cut the turbo side flange off and spin it then reweld it. i HATE SSAC but hey i have bad luck with everything so maybe yours will fit. but bolting that up to your stock should work, i mean everything iwas made to bolt up in those spots.
erm. negative.driftin8nez wrote:A good way to find where to activate the dump using an rpm switch is to do two dyno runs. One closed all the time one open all the time and where the curves cross is where you would set your dump to open.
So the rpm switch is more of a novelty? Becouse racing from a stop there will be a brief moment or two when the valve isn't open untimatly hurting performance. Where as with a regular toggle switch if you know your going to punch it you just open the valve first. Unless you set it at something like 3500 rpm and when you lauch you stay reved higher than that. So it would stay open. Interesting....tyrannix wrote:erm. negative.
having more restriction wont help a turbo engine, all the rpm switch will do is keep it quieter during low rev cruising, then open up when it knows you want to accelerate in a hurry
any kind of scavenging that would help an NA engine happens inside the manifold, before the turbo
CJ
I didn't get the one piece dp/tp but I got their 2 piece downpipe and testpipe set. Fits like a charm. No issues with anything, even bolts up to the exhaust bracket on the transmission mount.driftin8nez wrote:Also that SSA dp/testpipe should be able to bolt up the my stock exhaust without any problems?
Used the stock CA turbo elbow.UMS_CA18DET wrote:did you use the stock CA turbo elbow or the SSAutochrome/ SR20DET turbo elbow.
