:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Mon Aug 30, 2004 12:32 pm
ShiftDown -
I said this in the other post about this problem...the ECU could care less what cams are in the motor.
And OBD doesn't matter...I have run a '95, 96, and '98 ECU in my '96 car...with S13 cams, S14 cams, and JWT cams. They all made the car start and go fast, some better than other...but never the problems you're having.
And other than the valve cover and cams, the heads are basically IDENTICAL.
I'd wager that your timing (either cam timing or ignition timing) is way off, and the 5th gear switch is messing things up.
You can unplug the 5th gear switch, with no ill effects other than a CEL and the cruise control will be disabled.
Then check ignition timing, and maybe a compression test. If the cams are way off, you'll have bad compression...
Good luck.
Structure - The backup speed limiter on an S14 is a 5000rpm rev limit in 5th gear only...
- Brian
