audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Sun Oct 03, 2004 1:04 pm
Front end squeak could be your front struts. I have the same problem and know my struts are blown. Could also be the front sway bar bushings, or other bushings in the front needing replacement including strut tower. If the front seems to really jump about, I would look at the struts first.
For the window, you may be able to go into the door and grease it up a bit. If it is the glass making the noise when going up, you can try using something like rain-x on the inside and outside to help it slide past the rubber a bit easier.
