Yeah, probably a lot less lumens now.Mopar wrote: Both the headlamps and the fog lights are at 10K. I love the outcome. It's like day and night difference compared to the stock halogens.
Well in lamens terms...maxnix just really meant to park on flat ground about 20ft away and just shine your lights on a garage door for example. You will be able to see your cut off/beam pattern on the garage door.Mopar wrote:Thanks for the responses guys.......
I didn't know how to take a picture of the pattern, thanks for the tip.
thnx gammer, should we go to the car meet this thursday?gammer_ghn wrote:shez looking reall sexy man nice job!!!
Hmmm...relays just for the headlights to come on . Even though I don't have them in my car, NICO member BullitAndy installed some in his car, and I don't remember him telling me he had to install relays just for them to work.Mopar wrote:The HID's required some relays to be installed. I tried to install them myself, but could only get the foglights on since it's plug and play. For the headlights I had someone else to install it and it seemed a moderate amount of work since he had to run negatives and installed 2 relays to light them up. He also put a positive wire to the battery. Is that normal?
The wiring was not intuitive from what I remember. Its not + and - and so required some trial and error.NightRiderQ45 wrote:
Yes, that would be the optimal thing to do, but I got them adjusted and it doesn't blind the oncoming traffic. I have yet to be high beamed.te7two wrote:I was under the impression you had to install special glare shields to prevent from blinding oncoming traffic when you retrofit HIDs to a standard halogen setup.
I've been flashed twice in the months that I've had mine installed. There are bright but no blinding.Mopar wrote:
