Hey guys, you may want to check out one of our websites here
http://www.turbodatsun.com
my own daily driver is a D21 Navara with Z24 engine and blow through Weber turbo setup. If you click on the "DYNO MULE" button at the top of the page, you'll see a story of the different setups and dyno info. go to "stage 3" for the photos of the turbo setup.
Blow through carby is very simple, I'm not sure why it's gotten a reputation for being complicated, the only thing complicated is that you have to increase fuel pressure with boost pressure, or else the boost will force the fuel back into the fuel tank, but we have a fuel system with high pressure pump and fuel pressure regulator to take care of that.
We will be selling the the turbo kits soon, just doing the final touches now. And are already selling the blow through carby kits, have been for years, But the turbo and blow through setup give it a good 70% power increase over stock carby, and that's only at 7psi of boost. a 100% power increase is very easy.
For more dyno info and blow through related gear, you can check out one of the other websites,
http://www.turbogemini.com has the most info about blow through turbo stuff.
Cheers
