Larz »
https://forums.nicoclub.com/larz-u216291.html
Thu Aug 27, 2015 8:38 pm
Welcome to the forum!
Ant time you experience weird things with electronics or starting, the first and easiest thing to check is the battery. If the cables are not VERY tight, all sort of weird things can happen. I would check the cables first. If the problem persists, drive to an auto parts store and have them test your battery. These cars act up even before the battery actually gets very low.
Since you just purchased the car, I would take it to your local Infiniti dealer for an oil / filter change. My dealer allows me to bring my own oil (Mobil 5w30) and they charge me about $20 for the filter, drain pan bolt change, and labor). They will do a free, thorough inspection of brakes, fluids, tires, battery, brakes, suspension, warning codes, etc. Mind you, there is NO need to have anything on this list done by them, but it gives you a good starting point for your maintenance. The service rep will probably be able to tell you about the car's history as well.
