New here!
I have two sets of stock rims. What color should i paint a set?
BLAAAAAACK
3
75%
Dark Red
0
No votes
Blue
0
No votes
Cyan
0
No votes
Lime Green
0
No votes
Dark Green
0
No votes
White
1
25%
4 different colors!
0
No votes
Are you kidding? Dip them in chrome!
0
No votes
Total votes: 4
Oakshirus
Car: '92 Z32 [N/A T-top 2+0]
Hey guys, my name is Michael, i'm 19, and a while ago i bought a 1992 300ZX Z32 (N/A T-top 2+0) and i have a few questions!
First off, i read somewhere that the stock wheels are actually directional. Is this true? Which way is forward?
Second, the guy i bought it from (and another guy) said that with age the springs sag and give me some pretty nasty negative camber. How should i deal with this? If i get new springs, i'll have to replace them eventually anyway, right? So i'm leaning toward adjustable upper control arms? Would this do the trick?
Finally, i'm 6'1" and my knees rub the steering wheel (the wheel is pretty worn out and needs replacing too), any aftermarket steering wheel recommendations?
Thanks for reading! :chuckle:
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
Welcome! where you located? As for direction of the stock wheels the flat side of the hole not the pointed side should be going towards the front of the car. as for camber the rear has enough adjustment for sagging springs, the front if you want to save money could get the 300 degree camber kit or make your own, but adjustable upper arms will allow you to keep it correct for any future lowering of the car as well. Lastly I dont like most aftermarket steering wheels thus i just had mine re-wrapped but the Nardi competition wheel would be my first choice if i went aftermarket.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
As far as wheels go, my option would be gunmetal gray, especially on a black car.
$.02
z32loverboy
Car: 1990 300zx CRP N/A 5 Speed (wreaked, now a shell) SOLD
1993 Slicktop CRP N/A 5 Speed w/ '90 built N/A motor and interior
1958 Ford f-100 straight-body (Grandaddies truck, resto-project)
Welcome! +1 on the gunmetal gray wheels. I would for sure go with the adjustable control arms, make sure you get a good brand as well. I'm 6'3" and I fit pretty well in the cockpit of the Z, but I also have the seat pretty dang far back and adjusted as low as it'll go. do you have the electronic controlled seats or the manual seats? Also, if you look at the pic of my Z in my sig, you'll see that my wheels are on backwards. :gapteeth: I haven't had time to have the directional tires changed around to fix it lol
Oakshirus
I live in Indiana.
What brand would be good enough for your own use if you were to buy some?
They're electronic, but i like to sit up in the steering wheel, not very far back. So, my legs are bent a bit... Also, i think your rims are on correctly according to Z-Owned. lol
300ZXttZMAN
Welcome!
Look into SPL and powertrix for suspension, those 2 brands are the 2 best brands on the market for our cars.
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
Oakshirus wrote:Also, i think your rims are on correctly according to Z-Owned. lol
nope his are backwards the pointed part of the wheel opening is facing the front
Oakshirus
Oh okay, i misunderstood.
Found some Powertrix's for $336 from ConceptZPerformance.com. Am i going to have to spend another $150 on adjustable tension rods also?
DankZX
Car: 1991 N/A 300ZX: Few Mods
1996 Sentra GXE
Yes they usually go hand in hand and will both be needed to properly align your vehicle.
300ZXttZMAN
+1 ^
BlackWidowZ
Car: Black 93 300zx 2+2
welcome
DCaff300ZX
Car: .
1993 CRP TT- Modified
And in addition to the adjustable tension rods you'll need the front upper control arms, as well as the rear upper control arms for proper alignment. :dblthumb:
Oh Em Zee
Car: '96 Nissan Z32 Slicktop
'90 Nissan Z32 2+2
Fucas and Tension rods for the front
Toe rods and consider Rucas for the rear. NA's need toe rods in the rear. TT's dont because they have HICAS to adjust for toe.
As far as stock wheels? If they're not too beat, i vote keep them stock color!
H1tman
Car: '90 300zx 2+2 Azure Blue
Welcome. Powertrix...nuff said.
Oakshirus
Do the n/a and the TT have the same spring rates?
Oakshirus
I want to paint them because i have two sets. One set is staying stock, the other is going to be painted.
Oh Em Zee
'90 Nissan Z32 2+2
OEM TT and NA have different spring rates. TT is stiffer and I believe is closer to 2.1k front stock, while NA is something lower like 1.8k (just so you can compare against Powertrix 6/8k coilovers)
