New here! ok what should i be looking for??
N.O. Accorderz
ok recently i got an offer on a 92 fastback...it has no motor and he says it has intercooler piping from the previous owner...with the engine gone what should i be looking for? and major parts to be looking for and making sure its not gone...i'll be ordering a clip from daunt whenever i get the money...would the clip have everything i need for the swap? what if i was missing some parts off the 92 fastback...would i be able to use the parts off of the clip? and i was looking at the s13 redtop...baby slides right in right? no major modifications? sorry bout the long post...been checking out this tite site for awhile and finally found a 240 i like:ylsuper
harryhood
intercooler piping? what did the last owner have in it? i assume you know that all 240s came with an NA engine.if you get a clip (to my knowledge daunt is only selling motor sets which still have everything you need to swap but not everything found in a clip) yes it will have everything you need to swap and then some (assuming everything in the clip is legit).the engine and transmission bolt right up but you will need to do some ecu adjustments and some minor things to get it running.
if you're pretty heart set on doing this swap then just look at the shape the chassis is in and don't pay much for it.
you need to do some more homework though before spending any money towards a swap.
good luck
BuudWeizErr
ECU Adjustments?
I don't recall "adjusting" mine.
If this shell actually has intercooler piping, you should be able to tell by the hotpipe and the coldpipe what engine was in there. Start looking at the intake manifolds of CA18DET's, S13/S14 SR20DET's, KA24DET's, RB20/RB26/RB26DET's
The angle of the coldpipe should give it away, mostly. It was probably an SR20 or KA-T
N.O. Accorderz
the angle of the coldpipe? can u post some pixs...yea i dunno if he had the sr20 of a kat but he told me it had some ic piping but no motor
BuudWeizErr
N.O. Accorderz wrote:can u post some pixs
No, you can search for "pixs."
N.O. Accorderz
thanx bro...:D
Drakon
Car: S13 hatch-SR+bpu's
ECU adjustments are sending it to JWT and havin them reprogram it. You can buy the SR ecu for $300 but thats not even as good as having it done by JWT. but ur right in that i dont know why you would NEED to do that to get it running.
BuudWeizErr
JWT is not even close to the best option for a retune. That is unless you have a ton of money to spend (read: waste).
Drakon
Well I havent talked to anyone that ever recomended anything else. What do you recomend?
BuudWeizErr
Power FC or some other standalone.
Drakon
Isnt that kinda advanced and pricey?
SpeedRacer1
Car: 1990 240SX, G35
Some people just like to DIY with the help of a good dyno tuning shop. JWT is for those that dont have the time and/or skills and have the money for a retune everytime they change something. Besides, who wants to run a distributor.
