So, just figured I would give an update. I will update this post with links to the pictures from the past two weekends.
I have come to the conclusion of things Z owners have known, but still found a way to shock me. (My first ever Z)
In getting the car running again, I realized that the alternator was seized up. I managed to grab an alternator, power steering pump, and an AC compressor for 200. PS Pump and Alternator were never used remanned from Autozone, so I wasn't worried about grabbing it off of someone. Decided that if we needed to remove the belts anyway, might as well grab new ones. I figured, while I was in there I might as well change everything for the good stuff. Boy, did I not see the hours of frustration, aggravation, wanting to put a hammer through my own windshield (I didn't!!!) HELL that I was going to face to replace the alternator and PS pump.
To make a long story short, got them in, new belts, fixed the fuel leak and the coolant leak (stupid hose going to heater core) only to now have the brake line connected to the master cylinder spray fluid every time I step on the brakes. And then my dumbass self over torqued one of the nuts that the master cylinder mounts on on the brake booster.. snapped the bolt. SOOOOO add a brake booster to the build list which was just ordered. lol
But, I am going to recap everything I Have put into this car so far. I'm sure I am forgetting something. Here's to hoping I can get it going this weekend, replacing the booster and fixing that one line (stupid flare nut). Thanks for listening! ha.
Car - $300
PS Pump, Alternator, AC Compressor - $200
New tires and leather seats - $300
Clutch Master Cylinder - $32
Brake Master Cylinder - $61.49
Brake Booster - $80
Battery - $50
Slave - $15
I won't count the fluids or fuses that I have had to buy, but that's the running total right now. Just over $1,000.
Side note: Why the alternator and PS pump have to have that lip you gotta force them in?
