New here. I need to tap you guy's brain. ( I need your know how.) Please :help
240sxorty
Car: Just got a 89' 240 sx for a hundred bucks. Its problem. It ran lousy.
Hello everyone. I'm Knew hare. I juice got a nissan (gotta love that spell check) 89' 240 sx this past july for a hundred bucks. Its problem. It ran lousy. The guy was gonna sell it to a junk yard for the same price, so I got incredibly lucky. I just got done tearing the engine down to the block, and the chambers 3 and 4 are in bad shape. they are more oval shaped then cylidrical. What I need to know is this. what are my options as far as repair goes. Some pointers for having the block honed out, some measurements ( think the bore is 89 mm. Oh by the way its a ka24e) and best of all, how much I'm looking to spend. I found an engine rebuild kit that includes new pistons for $368 at importperformanceparts.net I know not to expect much from it. but I don't plan on shelling out the big bucks till I get the chassis in buns of steel shape. ( rigid that is ) All help and input is appricated.
-Even if you don''t know what your talking about. Say whats up. 240sxorty
DAEDALUS
Car: 1990 Infiniti Q45
How oval is it? What are the largest and smallest dimensions across the bores? Is it tapered too?
98s14inaz
Car: 2010 Nissan Titan Quad Cab
SOHC that his farked? Do the dohc swap and do 5spd if it isn't already. People are practically giving those dohc away.
Structure240sx
you could prolly swap in a dohc for less than that rebuild kit.
or jsut get another sohc to through in. would be a nice easy weekend to get it all done
slow s13
Car: cars, photo, music
yeah I would look in buy sell trade sections and get the DE motor then use all the great info on the boards to hook up your new DE motor
kane2g
Car: 92 240sx 95 240sx
98s14inaz wrote:SOHC that his farked? Do the dohc swap and do 5spd if it isn't already. People are practically giving those dohc away.
I just gave mine away last nite! just ask dan
Ubernoober
If you don't want to go through a swap to a DE (it is rather easy, but time consuming) simply go to a recycle yard and buy a running E. It may not be perfect, but for around 400-600 bucks, you could simply slip it in, and drive away. Easy and cheaper than a rebuild.Then, later on when you have built up some cash, swap in the DE or an SR. Or a 5.0, you know, whatever floats your boat.
