CPS »
https://forums.nicoclub.com/cps-u98655.html
Sun Mar 29, 2009 3:36 am
audtatious, he has an SER Altima, not a Sentra, so it did come with 18's.
xanztrik, you have quite an issue on your hands. First of all, you current tires are WAY too small, as your speedometer is off by 5mph right now. Your speedo, for example, reads 60MPH, when in reality you are going 55. The problem is that without knowing the actual rim width, it is going to be difficult to figure out what's going to fit the width of the rim (most important) that way you can determine what sidewall heighth to go with.
Assuming 235 is the widest you can go on the 17, you would need 235/50/17 tires to get within a 1mph difference at 60. There is no 235 tire that will get you dead on. A 225/55/17 tire would get you very close.
If it were my car, I would go back with the original wheels or an equivalent that is the width of the factory wheel. You are leaving a lot of performance on the table by having tires that are 10-20mm narrower than what it originally came with. Whoever had it probably needed tires at some point and realized how expensive the factory ones are, or had a set of 17's they liked and had them put on to begin with.
