new here had a question
boms209
Car: 1993 240sx ka24de
hey nico club i had a quick question i have a 93 240sx with the dual cam my starter whent out so i changed it but now it just makes a click noise everytime i try to turn it on the battery is brand new so i thaught it was the wiring so wat i did was connected a positive line from the battery to the starter to check if it was wiring but it still clicked so i looked it up and i found that it could be my starter relay but i cant seem to find it any ideas of where it can be or what else could be causing the problem?? thanks guys
laxands13
Car: 93 240sx Hatchback - Sold and missed
80 280zx - sold
83 Honda Civic Wagon - Current DD, soon to be CA16 powered
wow. Periods are your friend man.
Look in the electrical section (EL) and there is a starting system tab. When you click on that it brings up a diagram of everything your talking about.
http://www.nicoclub.com/FSM/240sx/91-94/
bigbadberry3
Do a quick check of your fuses?
allenms240
Car: 1991 Nissan 240SX
I know you said it's a new battery, but just try a jump start or a buddies battery. You'd be surprised.
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
the relay you are asking about is behind your battery. remove battery and its the blue relay. go to nissan not autozone type store. like 40 bucks.
LoserCard
Car: Forest Green 1993 240SX SE Fastback
Multimeter! Check voltage of your battery first, or have autozone do it for you. It might be a new battery but you may also have a drain or attempted to start it too many times.
DamonDread
Car: 1987 Toyota Supra Turbo
+1 for double checking your battery.
On a side note if you wired the starter straight to the battery then doesnt that bypass the relay, and elimate that as the problem. Faulty sylinoid on the new starter?
