nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Mon May 25, 2009 6:16 am
Prokit unless you change out the struts too. People have run Sportlines on stock ones, but it's not recommended as it can cause premature wear. If your roads are bad, probably best not to get anything too stiff anyway.
IMO 17"s are probably the better fit, but newer Sentras can handle 18"s if you want. Tires are markedly more expensive with 18"s though.
