New here and have few questions
Forum for the unique Murano, and official home of Nissan Murano Club!
truckintube
Hello Just joined the site.
I'm looking to buy used between 05 to 07 right now, all up on prices and what's available,what are the common issues and what to look for when I'm out test driving?I do have odbII reader to check the code, but mechanically what should I check into besides basic stuff.
testguy34
Car: 09 Nissan Murano SL
- check the engine compartment for any sign of oil leak (cylinder head gasket, brake, power steering, etc)- check shock absorber for oil leak too. if the suspension is not responsive, have doubt on it.- when test driving on rough road/cement, you must not hear any knocking on your suspension, else, there might be a problem on ball joints, tie rod, etc.- for automatic transmission, you must not feel (minimal to zero) changing between gears.- check brake: your steering should not vibrate when decelerating; should not hear any squeak when applying brake.
good luck!
truckintube
thanks thanks.is the color display comes with 06 and up right?
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
Since it's a CVT, drive very slowly in a parking lot, press on and off the gas gently and listen carefully for any grinding, rattling or otherwise abnormal noises. Remember that that CVT should be silent, even if a salesman may try to tell you otherwise.
Also, drive in a parking lot and turn the wheel all the way to the left and all the way to the right and make sure there is no clunking noise or "hopping" and "jumping", it should be completely stable, smooth and quiet.
Return to “Murano Forum”
