seang »
https://forums.nicoclub.com/seang-u122444.html
Tue Oct 06, 2009 9:00 am
Sounds cool, just make sure to check steering shaft clearence, and you might want a heat shield for the master cylinder/booster if its getting close. They even got those turbo wraps, too. IDK about the fuel pump and regulator either, but they are commonplace. The stock injectors are 270cc, and I think are good for up to 7psi of boost. The stock pistons are good for about the same, (comparably weak ringlands). Of course you have to fasten the charge tube to the throttle body with a carburettor style hat that screws down nice and tight. And the stock MAF sensor is integrated into the throttle body, IDK but I thought the MAF sensor was supossed to go before the turbo? Then there's the IAT sensor, but you might be able to get away without running that.
