kpc_0721 »
https://forums.nicoclub.com/kpc-0721-u55261.html
Sun May 10, 2009 6:51 pm
Problem is fixed now, POS distributor somehow stopped functioning while I took the head off.
The problem was not with lining up the cams at TDC. I am fully aware how to find TDC, and like the picture shows the cams line up perfectly at TDC.
I don't get why people say you need to put the chain on EXACTLY the way it came off, as long as the cams are aligned in the correct position you just put the chain on with the dark links on the marks of the cam gears.
thanks for the help guys.
