Bosworth Audio »
https://forums.nicoclub.com/bosworth-audio-u166753.html
Mon Sep 13, 2010 10:54 am
We just got done making our prototype exhaust for the F50 Q45 with impressive gains
The first round is a 2.25" true dual header back exhaust, all mandrel bent in mild steel for test purposes. The gains were quite impressive on what was measurable. We couldn't get a true dyno run all the way through because of the automatic in the Q, but where we could measure, 3,500rpms-5,800 rpms showed impressive gains.
Our stock dyno showed 252WHP and 268ft/lbs
after the header back showed 264WHP and 281ft/lbs
We couldn't measure the true low end torque, but there is a huge difference which is why we did 1/4 mile times also.
Before:
60' 1.976 @ 32.42638mph
330' 5.972 @ 57.41428mph
660' (1/8) 9.352 @ 73.85625mph
1000' 12.267 @ 84.51481mph
1/4 14.726 @ 92.36089mph
After
60' 1.714 @ 35.06204mph
330' 5.514 @ 59.80051mph
660' (1/8) 8.78 @ 76.33515mph
1000' 11.612 @ 87.08392mph
1/4 13.992 @ 95.14817mph
We're going to try a 2.5" mandrel header back also soon and also look into building headers as these numbers were with a cracked drivers side exhaust manifold and 94,000 miles on our 2002 Q45 test mule with staggered 20" wheels and 275 tires out back.
If there is interest, we will be creating a bolt on kit to replace the front y-pipe setup and the rear section that can be created in stainless or coated mild steel.
