burntricer wrote:I found a harness, from Dee, but i was just thinking, for roughly the same price i can scoop a megasquirt...
i just think it would be better in the long run
thoughts?comments? outbursts?
If you're prepared for that kind of expansion, go for it. The use of a standalone engine management allows you to be extremely flexible in the type of performance most of you expect from your engines. Again, if you're prepared to do the leg-work to get one installed, it would probably turn out to be a good investment. But as with any engine management, with an inexperienced tuner behind the controls, disaster is just a bad program away from happening. Good luck at whatever route you take.........
Dee
