Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Wed Apr 04, 2007 9:30 am
There is good aftermarket support out there for your truck, though I doubt many advertise here.
I run a Nissan 4x4 website, and we have gobs of tech available for your truck over there, but if you have specific questions, I'm sure you can get some answers here.
Stock steering is the weak link when lifts and larger tires are added. If you're keeping it stock, you should be fine. Nissan 4x4 lifts typically involve adding slightly longer upper control arms along with torsion bar adjustments to gain about 2.5-3" in the front, and Add-a-leaves and optional longer spring shackles in back.
When you do this, the factory steering centerlink goes away fast due to different forces being applied to it because of the new front suspension configuration. There are a couple aftermarket solutions for that as well.
Your truck will have the strong H233B rear axle (see my axle sticky at the top of the forum) with 4.625:1 gearing, most likely. It's the 31 spline 4 spider version which readily accepts the inexpensive lockrite locker, which can be had for under $400. This will do wonders for the offroad capability of the truck, but since it's a mechanical locker, it can be a little tricky when driving on icy roads. A more expensive, but better alternative is an ARB air locker, which can run open when not in use, and function like a spool when engaged.
