Lostintime123 »
https://forums.nicoclub.com/lostintime123-u216276.html
Fri Feb 22, 2013 4:40 pm
Thanks for the welcome. Now a few questions. I purchase the truck "as is" so it has some problems. The main one being that the mass air flow sensor was unplugged with the wiring harness that plugs into it being gone, this caused the truck to not drive above 2,500 rpm. I played around with it today and got the wires back on, could someone please tell me is i got the wires on the right spot. I had 3 wires, one being green with red stripe, one white, one black. I connected the green with red stripe ( which showed around 13/14 volts when connected to volt meter) to the top pin, then I plugged the white one into the middle pin and finally the black wire into the bottom pin. This allowed the truck to go above 2,500 rpm and actually idle well. I tested the voltage coming out of the black wire by probing with volt meter while the negative was connected to the battery and was get 1.4XX volts at idle and around 2.5XX volts when revved up. Is this the correct voltage I should be getting??
I have noticed that there are quite a few parts broken/missing. Does anyone know of anyone that has a parts truck they would be willing to give me parts off of. I'm willing to pay shipping etc., if not I may have to go visit the bone yard...
