Jonheu300zx »
https://forums.nicoclub.com/jonheu300zx-u248500.html
Thu Feb 26, 2015 10:45 am
Picked up a pearl white 1993 300zx TT and loving it. It's in great condition and ran ok when I first bought it. Has 179k miles. Is that high? Things I did was changed oil and filter with mobil 1 oil and filter, changed rear differential gear oil with Royal purple, changed out fuel filter, changed out sparkplugs, air filters, cleaned throttle body and MAF sensor, and tested all fuel injector which was in ohm specs, but the connections were corroded so I cleaned them and replaced the connectors. Now the car runs great and no more check engine light.
Next will be all preventive Maintinance which includes timing belt, all pulleys and tensioners, all seals, waterpump, thermostat, valve cover gasket, pcv valves and all fuel and vacuum lines. Love this car and love working on them.
Is there anyone near Fresno, CA that can help if I need it? Thanks guys
