Elisha »
https://forums.nicoclub.com/elisha-u25283.html
Sun Sep 30, 2007 9:49 pm
i had your exact issue with the DRL. i replaced it and it worked fine. but after that i had another almost similar issue.when in DRL i would get the passenger high beam only and on the driver side i would get really low power to both lights. the passenger low beam would not light up at all.and a buddy of mine figured it out.....on the problem was that passenger side low beam connector did not have an 0-ring in it so it was not sealing tight and the bulb pins were getting oxidized. so i used a pick to scrape off the pins in the harness and pull it closer a little so it made better contact as well.i didn't get a new harness plug but so far its working good but when the pressure is low and the weather is bad outside like rain, that one light acts up and i have to pop the hood and fiddle with it.this may not be related to your issue at all.but if you only have one light that is messing up, then its worth a consideration.
as for the replacement DRL unit, i paid $100 for it brand new. i also took apart the headlight relays and resoldered them before i replaced the DRL but that wasn't the issue.
