New guy on site, 720 owner
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
chance1980
Car: 1980 Datsun 720 2wd pickup L20b 5spd.
I just bought my fourth 720 last week and haven't had the chance to really look at it, but im sure the fuel pump is shot, it has the block mounted mechanical pump, what I'm wondering is if there is a pump by the tank also? i tried to start it and i check to see if the fuel line is plugged or whatnot, there was gas right up to the fuel filter almost to the pump, but when I crank it over it wont suck fuel, I pulled the inlet line off and cranked it and it sucks, anybody have any ideas? Maybe switch to electric pump?
1980 datsun 720 2wd 5spd L20b
chance1980
also want to figure out what to do with the electric wiring for the choke on my weber carb????
XavierBK
Car: 2011 Yamaha Stryker
1985 Nissan 720
What about the wiring?
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
are you sure that the Mechanical Fuel pump is working right?
You should be able to take off the valve cover and make sure the actuating arm isn't messed up or broken and the diaphragm is working.
I don't think they have another pump but I don't know/remember. I wouldn't see the point of having two for a stock 720. I have casting marks for Mechanical fuel pump on my z24 and ka24 blocks but its just empty space that my PS pump takes up.
breadbox
89 Koop
84 720 4x4KC
I wouldn't ditch the mech pump(I think they are neat) but electric pumps are pretty standard and easy to put on anything. Just know you have a hole in your head currently filled with a mech pump.
chance1980
XavierBK wrote:What about the wiring?
There is wiring on the side of the carb for the electric choke, but my truck doesnt have any hookups on the harness for it.
And i havent really checked to see if the pump is working right, Ill check it out on tuesday and update on here, I will also post some pics of my $50 datsun!!
XavierBK
1985 Nissan 720
For the electric choke, just tie it into a hot-when-running circuit.
chance1980
OK Ill do that tomorrow when i go work on it some. Pics will be up tomorrow or wednesday of the truck, thanks for the help guys, I was planning on lowering it, but it has this funky rear suspension where theres the leaf springs then coils on top of the axle. what should i do? take the coils out?
chance1980
Heres some pics of my ol girl. shes had a rough road but soon she will be better, still havin problems keepin her runnin, gotta drop the tank and flush the bad gas out of it, hoping thats the problem, maybe get a few ideas on how to maybe put some sort of additive in the tank to loosen it up???
Davezilla
Car: 1990 300ZX
1986 720 4x4
Best stuff I've found to get the junk out of a tank is KBS Aqua Klean from http://www.kbs-coatings.com It'll loosen up just about anything and you'll see all kinds of junk coming out of the tank... even if it looked fairly clean to start with. Just mix the stuff with water as per instructions, let it sit a while, slosh it around etc, pour it out, rinse, and you got a clean tank.
Return to “Datsun 720”
