New guy looking for some advice
Booner8269
Im looking to buy a 91-94 240sx se! Is there any type of problems i should be looking for, besides the small stuff that a 10 year old car has? Im basically looking for a good project car, this car seems like theres alot of options so i think ill be getting one shortly. Thanks for any advice
-mike
Anand
Car: 95 Nissan 240SX
Welcome to the boards....
Enjoy your stay and good luck with findind a good 240.
Try doing a search for this question since it has been asked many times before and you will be able to look it up and get your quesitons answered right away instead of waiting for people tp post...
98TURBOKA
Car: HOME IMPROVMENTS-MOUNTAIN BIKING- EARNING MONEY-MOVIES
welcome. I don't know of any specific problems to search for, just kinda cruise around the forums and you'll pick up on problems that others have had.
Meantime
Listen for the timing chain while it's running...that's about the only endemic problem.
240marcuSX
Car: E34 525i
E46 M3
ask them if it has anti-lock breaks, HICAS, or a stock LSD. having or not having one of these could cost you some money later on depending on what youre going to be doing with the car. You'll probably find water in the trunk of a fastback. so dont be surprised, if you do. Welcome, you've chosen an excellent car.
Eklectrick
Car: Photography, Computing
[quote=" 240marcuSX [B You'll probably find water in the trunk of a fastback. so dont be surprised, if you do. Welcome, you've chosen an excellent car. [/quote]
whoah, thats common? that makes me feel a little better knowing mine isn't the only one that does that.
nissanrcer240
Car: 90 Nissan 240SX SR20DET
Quote »whoah, thats common? that makes me feel a little better knowing mine isn't the only one that does that.[/quote]
lol you too??
rousie13
Car: 2006 Nissan 350z Track Edition, 1997 Ford F250 4X4
Thats weird, mine doesn't leak at all. I guess I must be really lucky with my 91 FB.
Cyberkreig
Car: 1993 Nissan 240SX SR
my hatch doesnt leak.. but my dome light fills up in heavy rain :confused:
240SXer
Car: 1995 240sx SE (2jz powered)
I just got a 91 SE. The motor or fuel system or ignition system or SOMTHIGN has a problem. It stalls occationaly and surges when it's driving. I still would have bought it knowing the problems but that's just me. They're all hard to find in the config I want it. Just make sure you inspect the car, and drive it and make sure everything works well. Check power windows, locks, etc. etc. etc.
David.
wiwalsh
Car: school, and my 240!
If you car is surging, try the O2 sensor 1st... Clean the MAFs, ... intake hose leak,.... thats a start
Dome light??? Thats weird!!!! Sunroof?
My 89 had a big a$$ leak in the trunk (the infamous tail light leak I never got around to fixing). It also had 2 bad widshield leaks I never got around to fixing.
240SXer
I didnt think it would be the o2 sensor.. it also has a fairly large loss of power...
wiwalsh
Thats true.... when i replaced mine, it smoothed it out, but never did restore the power, bout the only thing i had left to test/replace was the injectors. Their impedence was fine, but they were probably not working very well. (and I wasnt going to spend $400 on injectors for that beat up car)
240marcuSX
Car: E34 525i
E46 M3
yeah man, when i was first looking for my car, i found three other fastbacks with leaks. and ive seen some ones here with that problem too.
