New guy in the forums.Blown head gasket on my KA24DE.Need advice!!!!!!!!!!
bearsfan00
Car: 1991 240sx
I blew my head gasket racing a miata with an RX7 motor, ON THE HIGHWAY.I bought ARP head studs and a Cometic head gasket.Anything I might be missing that I should replace so that this wont happen again?!!!
s13_chris
Car: 90 240sx Hatch
Yah you did miss one thing. DON'T STREET RACE YOU IGNORANT LITTLE f***. INNOCENT PEOPLE COULD BE KILLED BECAUSE YOU HAVE SOME HARDON FOR A MIATA WITH A RX7 MOTOR!? Good f***ing logic dude. Grow up.
visser003
Car: 1991 Nissan 240sx Coupe
Oh lordy lordy lord. Thank you wise internet poster for showing us the way, no more street racin' fo us masta.
We definitely will listen to you over the internet oh all knowing one.
Back ON TOPIC:That should be all you need, check in the head for any bad stuff and clean it up before you stick it back on.Also, FYI some people have trouble with cometic head gaskets bc they need really smooth contact points. I would go with a felpro if you dont plan on getting your head machined.
killernoodle
Car: My daily: 2005 Cadillac CTS-V - pretty much stock
Brother's S13 project car: SR20det, wilwoods, suspension, q45 diff/axles, 315s out back
I don't see why you were racing another car on the highway, your car is slow, you know its slow, the guy in the slow RX7 knows its slow... what did you have to prove?
Make sure your head isn't warped.
bearsfan00
Car: 1991 240sx
I guess. I have a click/knocking sound coming from the head, not the block. Coming from under the valve cover. I think it's either the cams or som s*** in there. What do u think it might be???
PapaSmurf2k3
Site Admin
well, is it a click, or a knock?
How did you blow the head gasket anyway? Did you over-rev the piss out of it or something? Are you boosted? Running low octane fuel? These engines are pretty stout in stock form.
baron_harkkonen
Car: 1993 Nissan 240SX, 2005 Honda Civic
Miata huh? They're so ugly, there so slow. Even with the RX-7 rotary engine sexiness, I still wouldn't own one. Anyway, OP, you're gonna need some other gaskets besides your head gasket.
visser003 wrote:That should be all you need, check in the head for any bad stuff and clean it up before you stick it back on.Also, FYI some people have trouble with cometic head gaskets bc they need really smooth contact points. I would go with a felpro if you dont plan on getting your head machined.
Get a head set from either Felpro, or Victor Reinz. It will have everything you need, excluding head bolts (GET NEW ONES!!!!), to put it back together. Felpro is good for stock, and Victor Reinz is more or less used on performance engines.
