nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Tue Feb 04, 2014 8:34 am
Do the 6 P's located "everything you need to know about the z32". It sounds like you have a few issues, obviously, but the first thing to check is the ECU for codes.
After that, check for corrosion at the connectors, see if the injectors OHM out correctly (10-14). Anything over means they are bad, period. Check for vac leaks, fuel pressure after the filter. Fuel pressure regulator and damper, make sure neither are leaking and are doing their job. Maf could be dirty, causing a bad read to the ECU.
