Sil40sK »
https://forums.nicoclub.com/sil40sk-u29707.html
Thu Jan 18, 2007 5:13 am
Quote »what wires match up to with going form the ca maf wires to a ka maf.[/quote]Not to sound annoying, but please use the search function, the wiring can easily be found in old posts as this is a frequently asked question.
Quote »do you think i should run a vac line from my hot pipe not the intake mani?[/quote]Run a vaccum line before the throttle body??? That won't work, all the vaccum is created inside the plenum when the throttle body is shut. All your vaccum sources are after the throttle body. So run the line from your intake manifold.
Quote »to add to that i need a ca hot pipe if i cant get the one from my freind by this weekend wtb.[/quote]Just an fyi in case you didn't know, you can use any old SR20 hot pipe (assuming your running a stock turbo or one similar to it)
