Its a common misconception that you need to be able to rev to drift. All you need to be able to drift is a motor that will break the rear wheels loose.
The reason i bring this up, you can save yourself a crap load of money if you build your car smart. You dont need headwork done, and a 7000 rev limiter is fine. This is actually a bonus for you, RPMs have a tendency to ruin peoples motors... If you can make the needed power down low instead of up high, you have less risk of engine failure. The KA doesnt like to be reved, its engine geometry was not designed for high rpm operation. No amount of headwork is going to change this.
Go for the felpro headgasket under 500 hp, nuf said.
Also, whoever was telling you how to break in motors needs to get the update. Your actually supposed to beat the piss out of your motor, methodically (lol), to break it in. Check out this link, then be prepared to have a bunch of machinist who dont really know sht laugh at you when you tell them how to break in a motor.
http://www.mototuneusa.com/break_in_secrets.htm
