3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Sat Apr 18, 2020 11:40 am
Thanks-PM me and we can discuss what might be good to harvest.
I don't fault you for converting from Active.....as long as you do it right!
To be sure, actives are not for the faint of heart. And there is no ongoing support for them (Nissan doesn't even make the hydraulic fluid anymore--although I have started cutting in CHF-11s as a substitute).
Remember if you do go with the base (2-wheel steering) PS pump you will still need a pulley and brackets (even if you are planning to re-use your 7-groove with welding I think (not sure) that the pump shaft diameter and keyway are different).
If you can have a high pressure hose fabbed, I think you are on the right path.
The active pump suction hose is a long one with both metal and rubber and connects directly to the active reservoir, so leave that one as long as not leaking.
The active pump discharge goes via hose first to an accumulator that is just forward of the A/C clutch. you'll want to fab a re-design hose that goes from the pump outlet back to the reservoir. the reservoir return in the original design is a two part hose, with the main part coming from the active radiator. You can disconnect the lower hose from the active radiator and make that your connection from the pump output back to the reservoir (thru the active oil cooler). You mentioned pump output pressure-the max pump output is 1400-1500 psi, but it doesn't usually run at that level. I'd suggest orificing your newly fabbed hose so that you've got about a 0.050" opening to lower the pressure going back to the reservoir. That's just back of the envelope--YOU are going to be the engineer redesigning this if you go that route.
one other thing: that two part hose that goes between the oil cooler and the reservoir: I believe you will have to plug the smaller hose where it plugs into a small canister filter (identified with 3 hex screws in a triangle at the bottom of the filter)that is attached to the multivalve.
Of course, if you intend to re-purpose your active oil cooler as a transmission cooler or other (which is not a bad idea), then you'll need to fab a return to the reservoir that doesn't go thru the cooler.
One other important thing regarding loopback:
regardless of how you complete a closed fluid circuit for the pump, when you connect everything back up, you will need to suction the inlet line to the active pump, as air will trap and the pump will cavitate and eventually seize, rendering all your loopback effort for naught.
The way the factory designed this was to hook an a/c vac pump to the filler neck on the active reservoir. That does indeed work, and is important.....
AND....
bear in mind that at 26 years old, it is very likely that your active pump (in particular the solenoids on the bottom of the pump and perhaps the forward seal on the pump) is leaking. Both of mine were. I have resealed the pumps on both cars (and re-ringed the power steering side in the process). I mention this as another reason why if you do loopback, keeping the reservoir so you can check and maintain a quantity of fluid in the system is important.
