New guy. 4x4 hardbody issue
Minimonster
Hi guys I just recently bought a 4x4 king cab 5speed hardbody. Super clean. On 33s. I have owned many 240s. I have put together and swapped Rbs. Srs. And turbo kas. So I know my way around the tool box. I bought this truck to stick with my Nissan roots. This website has been helpful in the past.
My issue. Vg30e 5speed 4x4 hardbody. When I give gas in 1st gear it shutters. Almost like the maf is unplugged. But is fine in a 2nd gear. And free revs just fine. It jerks pretty good only past like 20% throttle. Could this be a bad maf? Bad knock sensor and it's pulling timming?tps? Truck is one of the nicest hardbodys I have seen. I really want this fixed. Thanks guys. Pics to come.
dvdswan
I would give it a tune up 1st. for the shutter, I would check the center support bearing on the driveline, its a common on a 2-piece driveline.
what yr is the truck? do you have a CEL?
Minimonster
What is a CEL? It's a 93. It has a LSD in the rear. And dune grapplers if that matters.
seang
Car: Ford Fiesta ST
CEL = Check Engine Light
The first thing that came to my mind was axle wrap, but I wasn't exactly sure what you meant by "shutters."
Minimonster
I checked the carrier bearing it's all good.No check engine light. Yea it has a 2 piece drive shaft. The engine is def cutting out almost like it's in limp mode. But you can ease on it and it's fine. I read something about some fuel conrol unit that goes bad and you have to mod it. Bypass it.it could be fuel cut. And Im also leaning toward the tps. And of you unplug the maf it dies. This normal? The s chassis would idle fine with no maf. Just ran in limp mode. Thanks for your help.
Modified by Minimonster at 2:43 PM 3/29/2010
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Sounds like clutch chatter maybe.
Minimonster
No I don't think it's that. 2 nd gear it's fine. Its def the engine bucking almost like a rev limiter. Thanks for the tip tho. Can't wait for this to be fixed.
seang
Car: Ford Fiesta ST
I remember a few weeks back there was a thread in the NA KA section where a member's car was doing something similar. I think it was some transmission sensor that failed, and he just unplugged it.
Minimonster
Is there any chance you could dig that up and give me a link? Or do you remeber the title of the thread? I looked threw the threads turned up with nothing. Thanks for the help fellas. Cany wait to see the full potential of my truck.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Throttle position sensor or a bad vacuum leak someplace is what I'm thinking.
Minimonster
On the kas,srs,rbs if the car dies when you unplug the maf that mean a vacum leak. Is this the same with the vg30e? Is it closed loop?becuase my truck dies when I unplug the maf.
seang
Car: Ford Fiesta ST
If I unplug my MAF sensor, it will run fine but blip out at like 2400rpm.
I can look again for that thread, but I didn't see it yesterday. If you have to, you can unplug the sensors on the transmission (except the reverse sensor) and try it. It is free of charge. I don't know which sensor is which, though. I will go try and find that thread.
Minimonster
My truck dies when I unplug the maf.
Minimonster
Turns out it is axle wrap. Who sells traction bars? Would a helper spring solve my problem? Thanks guys
seang
Car: Ford Fiesta ST
I'm not sure what kind of anti-wrap device would be best here.
I would say to make sure all the leaf spring bushings are not sloppy and have good shocks so that they aren't added variables.
