New Gt28r on s13 blacktop.
Sleeper_RMS13
Car: 91 FB W/Blacktop SR
I just finished up my gt28r turbo swap in my s13 and correct me if im wrong isnt the stock wastegate set for 9psi? Im only pushing out 5-6 psi right now. I triple checked for boost leaks and loose vacume hoses. Everything is tight and snug. I know I can buy boost controllers and what not but for now I just wanna make sure its even running how its supposed too. Honestly I miss my t25 at 12psi at this point. Any help would be appreciated!!
Sugar
Car: S13 w/ Sr
5 to 6 psi is low yeah. Did you change your intake set up at all? Even a dirty filter can cause low boost like that.
Sleeper_RMS13
Well I have the apexi super suction kit but Im waiting for my nistune to come in and run my z32 maf. so im still rockin the old filterand stock intakefor now but its clean for the most part.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Maybe the intake tube is collapsing under load.
Sleeper_RMS13
I Did a pressure test and it held all the way to 15 psi. And plus wouldnt it have collapsed under 12-13 psi on a t25 since im using the same stock intake? Im almost positive its the wastegate. I orederd one and hopefully it should come on friday .
Sugar
Car: S13 w/ Sr
Sleeper_RMS13 wrote:I Did a pressure test and it held all the way to 15 psi. And plus wouldnt it have collapsed under 12-13 psi on a t25 since im using the same stock intake? Im almost positive its the wastegate. I orederd one and hopefully it should come on friday .
I wasn't sure if you had modified the intake with the new turbo, if its stock and still has the metal coil in it then it won't collapse. Hopefully the waste gate takes care of it.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
^Agreed... Either a bad spring or a not-so-snug wastegate
Sleeper_RMS13
I changed the wastegate to the hks adjustable one and now I have 12 pounds easy. Problem solved and now much happyer.
