centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Tue Aug 01, 2017 1:14 pm
True, in most circumstances, but not all. I'm not sure what his thinking is about having to remove the TB, but maybe he does. The first time I ran into this I needed to replace TPS, the screws on there were literally screws, not bolts, so there was no way to fit a phillips to the end of them without removing the TPS. I even bought one of those 90 degree bent screwdrivers, but couldn't apply the necessary force to turn the screws. TB came off that time. Another time on another 240sx the TPS had bolts with hex heads, so it was easier, but still a pita and removing the TB would have made access a little easier still, though it was not necessary that time. The current 240sx has the hex bolts, but I was doing other things along with it, so the TB came off that time as well.
